Insert table format
npferreira
Insert table format
Post by npferreira »
Hi
First time contributing to beta - work stuff never allowed me to previous. As such, I'm unsure if what i'm pointing out is a default or a defect. Sorry if I'm in the wrong here.
So, 2 things.
First:
Im using the UI on (UI.png). I made a list (1.png) and I'm inserting a table (2.png). When it turns into a table, the header is black on black (3.png) - shouldn't the auto table format identify headers font color as auto also?
Second - and this one comes from previous 2024 version, and its annoying AF:
When I'm duplicating a sheet (4.png), the new sheet will loose all formating - even table attribute (5.png).
Re: Insert table format
Thank you for posting your issue, but you forgot to uploadthe screenshots you mentioned in your post.
Please post these screenshots for a better understanding of the issue.
npferreira
Sorry, here they are.
attach.7z
(140.76 KiB) Downloaded 255 times
I am unable to reproduce the first issue, so please share the file in which you are getting this problem.
I have forwarded the details of the second issue for further investigation.
npferreira
I've attached the file for the copy table problem.
Specially annoying because you'll have to update all table# references/formulas within the cell - for example, if original table has formula wiht "=[@Subtot.I]+[@Subtot.II]", it will be copied to copied sheet as "=Table8[@Subtot.I]+Table8[@Subtot.II]" - the original table name.
Likewise, after you insert as new table, you'll have to update all the table name references in the formulas.
Screencast from 2026-03-15 09-53-40.mp4
(2.04 MiB) Downloaded 211 times
Example.pmdx
(1.24 MiB) Downloaded 220 times
Thank you for sharing the file and the screen recording.
I see that these relate to the second issue you mentioned. I have already forwarded the details of that issue to our development team for further investigation.
Regarding the first issue (the title font color), I am still unable to reproduce it on my end.
Please ensure you have updated to the latest Beta version and test again. Let us know if the issue persists after updating.
Please check the screen recording below:
Return to “BETA: PlanMaker NX and 2026 for Linux”
