Create Organization Structure
dhanuarioputra
Post by dhanuarioputra »
Greeting, is there anyone knows how to create an organization structure? =D>
Re: Create Organization Structure
Thank you for your question. You can build an organization chart using AutoShapes. Here's how to access them:
1. Go to the Insert tab on the ribbon.
2. In the Objects group, click on AutoShapes.
3. Choose the shapes you need to create your structure.
Return to “TextMaker NX for Android”
