Hello!
I can't change language for spelling in any other language than English in which the FlexiPDF 2025 (64bit) was installed. I can choose other languages in drop down list and if they are not installed I get a window "Change Spellcheck Language" with option to Download the "selected language" dictionary and after klick on it everything closes. After that when I check (Optiona > Spelling) if the new spelling language was downloaded and used for spelling the language is back to Englis.
It seem that the 64bit version does not use the same hunspell location to store languages that 32bit version uses (\%AppData%\Local\FlexiPDF\4\hunspell).I couldn't find it on my Hard Drive.
So for me 64bit version is useless at the moment as I use more than one CE languages for spelling.
[32bit Version]
In 32bit version the languges that I need are working but I have to manually copy them to %AppData%\Local\FlexiPDF\4\hunspell\"Language_Folder" because downloading language creates only empty folder of that language that I want. Rest I have to do in SoftMaker Office 2024 > install spelling language > go to SoftMaker Hunspell folder (%AppData%\Roaming\SoftMaker\hunspell) and copy languge folder to FlexiPDF Hunspell folder (%AppData%\Local\FlexiPDF\4\hunspell).
Painstaking but it works. No luck in 64bit version for now. I hope you can provide me a solution to my problem.
Regards,
Spelling language - FlexiPDF 2025 (64bit)
1 post
- ↳ TextMaker for Windows
- ↳ PlanMaker for Windows
- ↳ Presentations for Windows
- ↳ BasicMaker for Windows
- ↳ TextMaker for Mac
- ↳ PlanMaker for Mac
- ↳ Presentations for Mac
- ↳ TextMaker for Linux
- ↳ PlanMaker for Linux
- ↳ Presentations for Linux
