No option to leave comments
RichardBenson
Post by RichardBenson »
Hi, I've just started using Textmaker NX for Mac, and am unable to find any option to leave comments.
In Review, the only group I have is Spelling.
In Insert, I have Breaks, Table, Objects, Links, Header/Footer, Text.
Highlighting and right click brings up a list of options, but comment is not among them.
I must be doing something basic wrong, but am foxed - would be grateful for any ideas.
Thank you.
stascheit
Re: No option to leave comments
Post by stascheit »
When you only have the group Spelling on the Review tab, it sounds like you are using FreeOffice instead of SoftMaker NX.
(Or you are using the old settings from FreeOffice).
Maybe you should do this:
- Close TextMaker
- Rename your Settings folder for SoftMaker\Settings in your Documents folder.
- and then restart TextMaker again
This will automatically create a fresh Settings folder (but without your original settings, which are in the renamed folder now).
Alternatively, you can also try to reset your settings, see screenshot:
According to our records, you are using FreeOffice. To ensure you receive the best support, I have moved your topic to the relevant FreeOffice forum.
In the future, please post in the FreeOffice forum to avoid any confusion.
Return to “FreeOffice TextMaker 2024 for Mac”
