Fedora 43 and install Fourth private beta
pfilipek
Post by pfilipek »
It's not possible to install Fourth private beta on Fedora Workstation 43.
Code: Select all
Transaction failed: Rpm transaction failed.
Warning: skipped OpenPGP checks for 1 package from repository: @commandline
  - package softmaker-office-nx-nx-1406.x86_64 does not verify: no digest
Another problem is importing the GPG key.
rpmkeys is now the official tool for manipulating the rpm keyring. Other methods such as manipulating gpg-pubkey pseudo-packages manually are deprecated and should be updated to either the rpmkeys tool or the newly provided keyring APIs.
Via: https://fedoraproject.org/wiki/Changes/ ... Experience
The commands dnf install --nogpgcheck do not work at all.
Because RPM 6 no longer verifies obsolete crypto by default, it's difficult to install other commercial software too.
Re: Fedora 43 and install Fourth private beta
Thank you for reporting this problem. I have forwarded the details for further investigation.
raitis.veksejs
Post by raitis.veksejs »
Workaround - when you have the RPM package, perform the installation through the command line with additional parameters like this:
Code: Select all
sudo rpm -ivh --nodigest ./[package name].rpm
raitis.veksejs
The issue will be resolved in the upcoming service pack, scheduled to be available soon.
Return to “BETA: TextMaker NX and 2026 for Linux”
