Presentations crashes on specific slide + visual artifacts
pdedecker
Post by pdedecker »
I have a PPTX that crashes Presentations when transitioning to a specific slide. On top of that there are multiple visual issues in the presentation (movies that are the wrong size, movies that don't play, items in incorrect locations. I will send the file to forum[at]softmaker.com. The best way to see the visual issues is to open the file in PowerPoint and compare directly.
Re: Presentations crashes on specific slide + visual artifacts
Thank you for sharing the file. I have successfully reproduced the crash while scrolling and have escalated the issue to our development team with the details.
Regarding the visual discrepancies, to help us target our investigation, could you please share a screenshot that highlights the specific area where you see a problem? A direct comparison makes it much easier than a component-by-component analysis.
pdedecker
Post by pdedecker »
I've sent a few screenshots comparing Presentations and PowerPoint to the forum email address.The easiest way to see them is to open the presentation in both powerpoint and presentations and to compare the rendering. I am looking at the presentation view in both.
Thank you, I have forwarded it for further investigation.
Return to “BETA: Presentations NX and 2026 for Mac”
