Error saving file. Disk full or inaccessible
cpraneri
Post by cpraneri »
Just upgraded from free 2021 to 2024. Attempted to save the first file using this upgrade and received this error. Tried renaming, different file extensions, tried saving as PDF so at least I'd have a picture version if I had to retype everything, also verified System settings allowed this app access to documents folder, reinstalled app, nothing works. Presently have file open on desktop and can't save it. Is there a solution? I'm MAC desktop Sequoia 15.6.1
PS. I do not have this problem in Planmaker 2024 - I can edit and save files.
Re: Error saving file. Disk full or inaccessible
Please grant "Full Disk Access" to the application and check if that resolves the error. If the issue persists, you can also try reinstalling FreeOffice.
Return to “FreeOffice TextMaker 2024 for Mac”
