Stand Alone Box and Grid Icon
rbruceterry
Post by rbruceterry »
For all the lines that one might draw around or within a spreadsheet, the Box and Grid is the most helpful. I imagine that it is the most often used, certainly by me if I am going to print it or paste it in a document. I would suggest having it available as an independent icon that could be put on a toolbar for quick access.
Re: Stand Alone Box and Grid Icon
Thank you for your post. Since you use “Box and Grid” most frequently, it will already be the default for the “Cell Border” dropdown. A quicker method is to add the “Cell Border” command itself to your Quick Access Toolbar. You can then apply your preferred border with a single click, as shown below:
Return to “BETA: PlanMaker NX and 2026 for Windows”
