"Save As" directory issue
kenj
Post by kenj »
Expected:
When using "Save As", the resulting file should be defaulted to the current working directory unless otherwise specified.
Is:
Working as expected except when saving existing document (ie .cvs, .xlms) to .pmdx format.
The default is then swiched from the current working directory to /home/SoftMaker/PlanMaker NX templates.
Tested on Arch Linux (KDE) , CachyOs (KDE), Alma Linux 10 (Gnome)
Re: "Save As" directory issue
Thank you for reporting this issue. I am able to reproduce it and have forwarded the details.
Our developer team have fixed this issue and the solution will be included in the next beta update.
Return to “BETA: PlanMaker NX and 2026 for Linux”
