selecting data in sheet
robert006
Post by robert006 »
Hi,
In another popular spreadsheet, you can easily select all cells containing data by clicking on the rectangle at the top left of the cells. That will select only cells which contain data. However, in Planmaker this will action select all cells in the sheet (over a million rows). Could it be changed to the former behaviour, which saves effort?
Re: selecting data in sheet
Thank you for reaching out with your query. To better understand your requirements, could you please share a screen recording demonstrating the specific rectangle implementation you're referring to?
robert006
Post by robert006 »
Hi,
If you are at cell A1, the rectangle is to the left of the A in column A and above the 1 in row 1.
Could you please specify which 'another popular spreadsheet' you're referring to? Knowing the exact software will help us provide better guidance.
Additionally, sharing a brief screen recording (or screenshots) would greatly help us in understanding.
robert006
Post by robert006 »
Hi,
Unfortunately, I cannot remember the situation which caused my enquiry. Today, when I try the selection in Planmaker and in other spreadsheets, the behaviour seems to be the same in all of them. My apologies for not being more helpful - if I encounter the situation again I will add it to this thread.
Thanks for your help.
robert006
Post by robert006 »
Please see my previous post regarding pasting of decimals - I added some information on how to reproduce the problem.
Return to “PlanMaker 2024 for Windows”
