Default settings location
seasidepb
Post by seasidepb »
Is there a way to change the default configuration/settings location? In Options I can see how to change the template location, and also how to import/export my modifed configuration files, but I really want to stop SMO looking for them on OneDrive, which is so sluggish that it often creates file conflicts when I move between my desktop and laptop. I'd really like to relocate them to another cloud service, or failing that onto the C drive. Forgive me if there's an obvious answer, but I can't see it.
Re: Default settings location
Thank you for your post but by default settings of SoftMaker Office should be located in My Documents folder which will be in OneDrive if you have configured your OneDrive in such a way.
You can exclude My Documents/SoftMaker folder from OneDrive, but for more details, you have to check in OneDrive help section.
