How to open files in separate windows?
Post by 2249 »
Hello.
How to open multiple files in separate windows? Can i do it? If yes - how? Currently, individual files open as separate tabs.
stascheit
Re: How to open files in separate windows?
Post by stascheit »
You can do this by enabling the option New program window. Once enabled, a file is always opened in a new program window, until you disable this option (even if you close and reopen PlanMaker).
Where do you find this option?
a. Choose the command File | New, a menu opens, select "More" here.
In the following dialog box, you will find this option New program window on the right side.
Select a template and click on Ok.
b. Choose the command File | Open, a dialog box opens to browse your files.
You will find this option New program window below the window that displays the files.
Select a file and click on Open.
It doesn't matter if you enable this option for File | New or File | Open, this option is synchronized for both.
stascheit
Post by stascheit »
Another method, if you don't want to be fixed with the option "New program window" enabled/disabled:
Drag the tabs to have it more quickly (click to see the screen capture).
2249
Post by 2249 »
@ stascheit
Now everything is fine ! Many thanks for your time! Greetings!
Thank you !
Devonboy78
Post by Devonboy78 »
Thanks for that tip, stascheit , I now use it frequently.
