If the image you are trying to drop onto a blank sheet is larger than the sheet it overflows it AND it is very difficult to resize it to fit without considerable effort.
The only successful way is to
Insert>Picture File location ENTER
then the image is correctly resized
drag and drop of images
raitis.veksejs
Re: drag and drop of images
Post by raitis.veksejs »
I was able to reproduce the differences between image drag-and-drop and Insert>Picture frame>From file. I'll ask our developers' team if it is the intended functionality or issue.
To resize the image after drag-and-drop more comfortably you can decrease the zoom level of the slide with control on the right lower corner (+ or - sign).
Return to “BETA Presentations 2024 for Windows”
- ↳ TextMaker for Windows
- ↳ PlanMaker for Windows
- ↳ Presentations for Windows
- ↳ BasicMaker for Windows
- ↳ TextMaker for Mac
- ↳ PlanMaker for Mac
- ↳ Presentations for Mac
- ↳ TextMaker for Linux
- ↳ PlanMaker for Linux
- ↳ Presentations for Linux
