any upgrade discount from previous FlexiPDF version
fuzzygel
Post by fuzzygel »
just wondering whether there is any discount I can use if I upgrade from previous version
Re: any upgrade discount from previous FlexiPDF version
Yes, as you can check on our Online shop - FlexiPDF 2022, there are huge discounts going on (maybe for limited time) for upgrading from FlexiPDF 2017 or 2019. Please check and you will get upgrade discount.
Does the upgrade include Corel Paintshop Pro?
Yes.
Yes, you can check our official website also for details of discounts. I have also mentioned the product link above.
Return to “FlexiPDF 2022”
