The subject line says it all. I write something, go to save as, select "Documents" or some other folder. When I name the file and hit save I get a file not found error. However, I CAN save to the desktop.
Any ideas?
Thanks!
John
"File not found" error using "save as" in Textmaker (Win 10)
Re: "File not found" error using "save as" in Textmaker (Win 10)
It's possible you might have enabled Windows Controlled Folder Access that is preventing our programs from saving into the Documents folder.
You may add our apps to the whitelist or disable the feature:
https://support.microsoft.com/en-us/hel ... s-security
- ↳ TextMaker for Windows
- ↳ PlanMaker for Windows
- ↳ Presentations for Windows
- ↳ BasicMaker for Windows
- ↳ TextMaker for Mac
- ↳ PlanMaker for Mac
- ↳ Presentations for Mac
- ↳ TextMaker for Linux
- ↳ PlanMaker for Linux
- ↳ Presentations for Linux
