character set for import text to PlanMaker
Hallo, please, is there an option to set the default character set for import text to PlanMaker? Every time I have to choose the right one from the menu from "other"... thank you
						Re: character set for import text to PlanMaker
Hi, I'm going to suggest to the developers that the default option could be the last-used one.
Thank you for your feedback.
				Folgore_202
Speaking of characters, are Greek ones available? Because I have to do a huge data folder regarding these villas for sale in Athens for the company I work for, and some of the data I need to add will be in Greek (addresses, names etc). Do I need to use special characters, or can I just copy-paste Greek text from the Internet?
Yes, Greek is supported if you select UTF-8 for the codepage of your database. You may then copy+paste.
