Saved "Network" hyperlink, changed into a normal web-based directory format.
After worksheet is closed, and opened later.
Hello,
I am a busy member of some communities.
To have a simple sort of "look-up" of subjects database what is written in past,
I do write the subject name and a short description within a worksheet.
Including a hyperlink behind those descriptions, going to the web-pages of the subject directly.
For some information I have collected files (E.g. PDF, docx and text files) to look-up myself,
and do have these files stored at a central file-server at home.
So I do want to write hyperlinks written within the worksheet, that redirect to these network directories and files.
The written hyperlink to a network directory and file is working right as long as the worksheet is open.
However as soon as a worksheet is closed, and opened a next time,
the behind hyperlink structure is changed into a "web based" hyperlink structure.
And by that not working any-more as a "Network" file directory string.
How can a hyperlink keep saved within the same structure without changing it after closing the worksheet.
As an example, the following network link:
\\192.168.10.1\__HD_Seagate-4TB\_Synology\Specs_DS415+.txt
is changed into:
//192.168.10.1/__HD_Seagate-4TB/_Synology/Specs_DS415+.txt
And by this change, not working an-more as a hyperlink to my network drive storage.
Re: Saved "Network" hyperlink, changed into a normal web-based directory format.
Hi, what version of PlanMaker 2018 are you using?
(Office) PlanMaker 2018 Profesional 2018 - rev. 966.0704 - 64bit
OK. I have reported your issue to the developers. Thank you!
Unfortunately still not corrected in the new Service Pack 2019-08-14: Revision 968:
https://www.softmaker.com/en/servicepac ... -changelog
Hi, unfortunately it's still under analysis. I'll let you know here when there's a fix.
