pmdx vs xlsx - Linux [SOLVED]
Klaas Vaak
Post by Klaas Vaak »
Planmaker encourages one to save files in the pmdx format to be able to make full use of its features. What are the features that cannot be used when PM saves a file in xlsx format?
Re: pmdx vs xlsx - Linux
Post by sven-l »
When you look into the PDF manual you will find some features (e.g. some special formulas) which only exisits in PlanMaker. These features cannot be stored in the MS Excel file format.
Klaas Vaak
@Sven: thanks for that Sven, I downloaded the manual and found it.
BTW, the manual is not quite up-to-date,as an example:
to edit range names, the manual says:
Choose the menu command Worksheet > Names > Edit.
In reality, the user should go to tab Formula > Edit names.
There are more instances where the direction is not quite right.
