Textmaker will not launch
muffin
Post by muffin »
Hello
I use Softmaker18 on an Arch Linux OS. When I launch Textmaker I get the following error:
error while loading shared libraries: libidn.so.11: cannot open shared object file: No such file or directory
I did a wild card search using:
ls -la /usr/lib/libidn*
lrwxrwxrwx 1 root root 16 May 19 06:17 /usr/lib/libidn2.so -> libidn2.so.0.3.4
lrwxrwxrwx 1 root root 16 May 19 06:17 /usr/lib/libidn2.so.0 -> libidn2.so.0.3.4
-rwxr-xr-x 1 root root 116408 May 19 06:18 /usr/lib/libidn2.so.0.3.4
lrwxrwxrwx 1 root root 16 Sep 10 21:48 /usr/lib/libidn.so -> libidn.so.12.6.0
lrwxrwxrwx 1 root root 16 Sep 10 21:48 /usr/lib/libidn.so.12 -> libidn.so.12.6.0
-rwxr-xr-x 1 root root 210728 Sep 10 21:48 /usr/lib/libidn.so.12.6.0
It appears that libidn.so.12 is there but not libidn.so.11.
Planmaker et al load ok.
Thanks for any help given.
kgha
Re: Textmaker will not launch
Post by kgha »
Always a nuisance when you've upgraded libraries and a program expects an older version.
A dirty workaround I often use, which might work in your case (no guarantees, though) is creating a symlink:
ln -s /usr/lib/libidn.so.12.6.0 /usr/lib/libidn.so.11
This ought to be addressed in a future upgrade. It's odd that Planmaker (and Presentations?) is happy with libidn12 while Textmaker isn't.
