Date format
Date format
Why no Hungarian format when language is set to Hungarian?
Re: Date format
Is your date format in macOS set to the correct Hungarian format?
Re: Date format
Yes of course. In Excel I can set date format in Hungarian, for example: 2018.07.04. but this format is not working in PlanMaker. In PlanMaker is looking this: 04/07/2018 and there is not possible to set this format: yyyy.mm.dd.sven-l wrote: Tue Jul 03, 2018 9:59 am Is your date format in macOS set to the correct Hungarian format?
Re: Date format
Please check your macOS system settings. PlanMaker usually uses the date/time settings from the system.
Re: Date format
OK... I write down again: in macOS system settings date/time is Hungarian. This is Hungarian format: YYYY.MM.DD. HH:MM:SSsven-l wrote: Mon Jul 09, 2018 3:53 pm Please check your macOS system settings. PlanMaker usually uses the date/time settings from the system.
In PlanMaker there is not YYYY.MM.DD. format. And when date in xls or xlsx is 2018.07.20. format in Excel, then in PlanMaker same date is 20/07/2018 format in same document.
Re: Date format
We can now reproduce that issue here and will report it to the developers.
Re: Date format
Thank you!sven-l wrote: Mon Jul 23, 2018 10:55 am We can now reproduce that issue here and will report it to the developers.
Re: Date format
When will release that update?sven-l wrote: Mon Jul 23, 2018 10:55 am We can now reproduce that issue here and will report it to the developers.
raitis.veksejs
Re: Date format
Please wait for some of the next service packs.
Re: Date format
There was an update and nothing changed with date format. And this problem is on Windows too. If date format in Excel is hungarian YYYY.MM.DD. then unfortunately in PlanMaker this format will DD.MM.YYYY.
I bought this software but I not use because of this problem... When will work date format correct?
Re: Date format
Your problem is handled in ticket 30766. I checked with the developers again and will report here as soon as we have a solution.
Re: Date format
Thank You!sven-l wrote: Wed Oct 10, 2018 5:13 pm Your problem is handled in ticket 30766. I checked with the developers again and will report here as soon as we have a solution.
Re: Date format
Unfortunately date format problem is still in this app. There is no YYYY.MM.DD format with hungarian language. I don't understand why. There is only YYYY-MM-DD and all other format is reverse: DD/MM/YYYY, DD/MM/YY, etc. This is not good because the app replace automatically all date for bad format.
Is it such a big task for developers?
I bought this software. Please solve this problem!
Re: Date format
We have an ongoing bug fix related the Hungarian date format. I'll include this thread in it.
Re: Date format
And I have to write date in this format: 12-03-2020 (DD-MM-YYYY). Because if I write date in original Hungarian format (2020.03.12) (YYYY.MM.DD) then it will not date. I don't understand this problem. This is old problem with this app...
