Compare SoftMaker Office Pro 2016 to 2018
cyaclone
Post by cyaclone »
It would helpful if there was a comparison between the 2016 & 2018 versions of SoftMaker 2016 to 23018.
To make an upgrade, one must first know why?
To answer that question, a chart showing the upgrade version compared to the prior product would provide the necessary reasons to make the change. If the versions are the same except for the number, then there is no reason to make the upgrade.
Re: Compare SoftMaker Office Pro 2016 to 2018
Post by Jossi »
Have a look at the blog posts at
http://www.softmaker.com/en/blog
cyaclone
Post by cyaclone »
Thanks for the info. It is what I had been looking for.
