Spreadsheet and Presentation icons reversed
Post here those questions, bug reports and suggestions for SoftMaker Office 2018 for Linux that do not fit in any of the application-specific subforums.
plus1
Post by plus1 » Sun Jan 13, 2019 7:40 pm
Installing from the deb package using the MATE desktop my Spreadsheet and Presentation icons are reversed in the system menu (under office). Clicking on the Spreadsheet icon brings up Presentation and clicking on Presentation brings up spreadsheets.
In MATE It is a simple fix:
either
right click on the menu entry, then click on the icon in the launcher. Select the correct icon from the list and close the launcher dialog.
or for a system wide change
navigate to /usr/share/applications. Edit (as root) the spreadsheet and presentation desktop file side by side. Copy /cut the icon filename next to the Icon= entry in either of the desktop files and paste into (not over the top of) the other desktop file Icon= entry. Then do the reverse.
I'm not quite sure how to force the MATE Advanced Menu to refresh its cache. Normally just log off or reboot to reset the menu cache should do it.
Re: Spreadsheet and Presentation icons reversed
Post by sven-l » Thu Jan 17, 2019 2:38 pm
The icons are not reversed. The green icon with the "P" in it is the icon for PlanMaker. The orange icon with the "S" in it is the icon for SoftMaker Presentations.
