popup menu disappears
Post your questions, bug reports and suggestions here for TextMaker 2018 for Windows.
MitchLeavitt
Post by MitchLeavitt » Sun Aug 25, 2019 6:24 pm
When I select an option from a toolbar (for example, to change font, or text color, etc), the menu appears, but then when I move the cursor onto the menu to make a selection, the menu immediately disappears before I can enter (highlight) the selection. This has occurred after updating from WIN7 to WIN10, downloading and re-installing SoftMaker Free 2018, as well as many other changes to my computer. So the problem may well be elsewhere, and NOT directly with TextMaker. Thanks for any ideas.
Re: popup menu disappears
Post by miguel-c » Tue Aug 27, 2019 11:12 pm
Hi, I wasn't able to reproduce the issue you described on my Windows 10 machines in either FreeOffice 2018 v966 or SoftMaker Office 2018 v968.
You could close all applications and then rename your Documents\SoftMaker folder to Documents\SoftMaker-old to reset FreeOffice settings, but I think the issue could be related to something on your Windows.
