Are there any ways to run TextMaker headlessly to convert .docx files to PDF? I've been using LibreOffice for this and it's quite slow. (I _think_) LibreOffice can also only convert one doc at a time per process. I'm looking to use this to create a micro-service for conversion, for a bit more context. Currently using https://github.com/unoconv/unoconv to do this with LibreOffice.
Thanks!
Convert .docx to .pdf from the command line, headlessly?
drdocument
Re: Convert .docx to .pdf from the command line, headlessly?
Hi, it's possible to convert to PDF using the commands below:
TextMaker:textmaker.exe /pdf:"myinifile.ini"
PlanMaker:planmaker.exe /pdf:"myinifile.ini"
SoftMaker Presentations: presentations.exe /pdf:"myinifile.ini"
See attached PDF with more details.
- PDFexportINI.pdf
- (844.76 KiB) Downloaded 6318 times
drdocument
Wow, this is fantastic! Thank you for sharing the document.
I tried this on Linux just now and realized I need to turn the forward slashes in to dashes, e.g.
I noticed that this isn't really headless as TextMaker does open a window momentarily to do the conversion. Is it possible to turn that off as well? If not, I think I can work around this with a framebuffer, but I thought I'd ask.
Thanks again!
Code: Select all
textmaker18free -pdf:pdfexport.iniThanks again!
Unfortunately it's not possible to turn it off.drdocument wrote: Wed Aug 07, 2019 6:43 pm Wow, this is fantastic! Thank you for sharing the document.
I noticed that this isn't really headless as TextMaker does open a window momentarily to do the conversion. Is it possible to turn that off as well? If not, I think I can work around this with a framebuffer, but I thought I'd ask.Code: Select all
textmaker18free -pdf:pdfexport.ini![]()
Thanks again!
drdocument
Got it - thanks for getting back to me on that point!
Hello,
I can't make it work on MacOS or Linux.
I have tried with many options:
Here is my ini file (UTF-8, three first byte are EFBBBF):
I have discovered in the german forum that there are over command line options such as `-disableopengl`.
Could you please give us the complete documentation of these options?
Thank you
Code: Select all
/Applications/SoftMaker\ FreeOffice\ 2018/TextMaker\ Free\ 2018.app/Contents/MacOS/textmaker -pdf:"test.ini"
opens textmaker but it does nothing
/Applications/SoftMaker\ FreeOffice\ 2018/TextMaker\ Free\ 2018.app/Contents/MacOS/textmaker /pdf:"test.ini"
gives the error "Impossible to open the file /pdf:text.ini"
Thank you
- Contact:
This feature is available only in SoftMaker Office, not FreeOffice.
Thank you for your fast reply. I will try.
is there a special license available of SoftMaker Office to allow a commercial usage of document conversion on many servers?
- Contact:
You need to contact sales (at) softmaker.com to discuss your requirements.
