Cut & Paste in Planmaker office 2024
21ch181
Post by 21ch181 »
Good morning,
I'encountourn an "funny" error yesterday !
Yesterday i use ctrl+x & ctrl+v to cut and paste a group of cells with formula and i was surprised to obtain "#error" in all cells.
I tested the same cut & paste a 2nd time with mouse : in that case, the cut & copy run well without any errors : all formulas were right with the good results !
Is there anybody have the same error?
Is there any solution (except moving with mouse) to solve that ?
I'm running Office 2024 on Ubuntu 22.04.
** Update **
I did some new tests this morning and ... it's strange ...
if i have simple formulas like sum, no error with ctrl+x & ctrl+v
In my previous file where i have errors with formulas with 2 if condition inside:
1- if i use relative references ==> error or wrong calculation after ctr+x & ctrl+v (no error with mouse movement). The calculation error is due that the cut + paste conserve the relative references (if reference is A24 and i cut+paste 2 column far away, the formula has C24 instead of A24 ... i hope it's clear !)
2- if i use absolute references ==> no error, no wrong calculations after ctrl+x & ctrl+v
Very strange ...
Have a beautiful day
21ch181
Re: Cut & Paste in Planmaker office 2024
Post by 21ch181 »
Hi everybody,
It seems that no one else has this problem...
Too bad.
Thank you for posting your query. Yes, you are right since it is working as per design.
Return to “PlanMaker 2024 for Linux”
