Enlarge toolbar
hkbs
Enlarge toolbar
Post by hkbs »
Is it possible to increase the size of the toolbar, please?
I cannot see it clearly on my laptop.
Re: Enlarge toolbar
Please click on menu Tools > Options > Appearance tab > User interface > Check the option “Touch mode (large icons and menu entries)” > OK.
hkbs
Re: Enlarge toolbar
Post by hkbs »
Sadly, this makes very little difference. On my PC, it’s fine but much too small on my laptop.
Re: Enlarge toolbar
Thank you for trying. Please click on menu Tools > Options > Appearance tab > User interface size > Use the sider under “Size of dialog elements” and set for your desired interface size > OK > OK. TextMaker will ask you for app restart.
hkbs
Re: Enlarge toolbar
Post by hkbs »
That’s better! Thank you.
