Very slow opening of the FreeOffice applications on Windows 10
Note: File created by Admin.
- tmlog.txt
- (38.38 KiB) Downloaded 1570 times
Re: Very slow opening of the FreeOffice applications on Windows 10
As you are using FreeOffice, please post your issues in FreeOffice forum only. For now, I have moved your post and created a file also with the log you sent.
We have released FreeOffice 2024 so it's recommended to upgrade your FreeOffice 2021 to 2024.
Please share some details of the problem like is this with specific file only or with all files?
Are you also facing problem with PM/PR? etc.
Using FreeOffice TextMaker 2024 (rev F1222.1129) 32bit.
Very slow opening large documents. Specifcally, converted from PDF. Takes up to 20 secs to open a 34MB file.
Could you please share the tmlog.txt similar to the one shared by the user above, using the same large document?
This will help us analyze the situation and determine if there is anything we can do to resolve it.
