Incorrect e-mail address while trying to ask for product key
Panda92
Post by Panda92 »
Hi
I am trying to activate FreeOffice 2024 - Textmaker. When I click on "Get free product key" and I enter my e-mail address, it takes a while (about a minute) and then I get an error message "Incorrect e-mail address".
What are the requirements of the e-mail address to get a product key? I am using my current e-mail address that I have been using for years without problems to send and receive e-mails.
Any help is appreciated.
Best regards
Andi
P.S. it is the same address that I used to register to this forum
Re: Incorrect e-mail address while trying to ask for product key
The requirement is that you should have a working mail server. :-)
You publish an IPv6 address for the MX record of your domain, but no server responds there. Either configure your mail server to listen on IPv6 or remove the IPv6 from your MX DNS record.
Panda92
Post by Panda92 »
Thanks for the quick answer.
Didn't realize that IP6 traffic was not working as IP4 is OK.
Best regards
Andi
