I would like to share a solution to a problem when uninstalling Free Office 2024, in which the Syspin64.exe error appears.
Take MSI package.
Edit the CustomAction table using the Orca program.
Delete rows in the table:
UNPIN_TM_FROM_TASKBAR
UNPIN_PM_FROM_TASKBAR
UNPIN_PR_FROM_TASKBAR
And the error does not occur anymore.
Error syspin64.exe when uninstalling FreeOffice 2024
Re: Error syspin64.exe when uninstalling FreeOffice 2024
Thank you for your workaround suggestion.
Our developer team have fixed this problem with the latest revision 1218.
I'm not having this problem but would you know a solution to uninstall Freeoffice when it keeps looking for the standard documents directory that no longer exists? It doesn't continue the uninstall because it fails to find the directory
Which directory it's looking for? Please share complete details with screenshots.
- Contact:
That's because when you are installing the latest FreeOffice 2024 using the latest MSI, it is running the MSI of the old installed FreeOffice (which still has the problem) to perform the uninstall.
Again, ignore the error message. It does not do any harm.
