Installs, upgrades, downgrades on Opensuse all fail with Segfault
vtpoet
Post by vtpoet »
Seems that something has changed in Opensuse. It's no longer possible to install, reinstall, or upgrade Softmaker. They all end with a segfault.
Code: Select all
Updating theme hicolor /2 of 2/
Registering MIME types...
Creating /etc/SoftMaker folder...
Installing for user vtpoet
And then everything locks up until one ctrl-c's out of the installation with a segfault. This bug occurs with older versions of SO that previously installed correctly.
Host: neugerig Kernel: 6.0.12-1.ga6c4f4e-default arch: x86_64 bits: 64
Desktop: GNOME v: 45.1 Distro: openSUSE Tumbleweed 20231108
softmaker-office-2021-1046.x86_64.rpm & softmaker-office-2021-1068.x86_64.rpm BTW
payamf
Re: Installs, upgrades, downgrades on Opensuse all fail with Segfault
Post by payamf »
I'm running into the exact same issue on OpenSuse Tumbleweed.
Was previously running version 1064 when I got notification about version 1068.
Code: Select all
Installing that stops at this point
Extracting resource files...
Using existing xdg-utils
Create MIME
Adding document icons. This may take a few minutes...
Updating theme Adwaita /1 of 2/
Updating theme breeze /1 of 2/
Updating theme breeze-dark /1 of 2/
Updating theme hicolor /1 of 2/
Updating theme Adwaita /2 of 2/
Updating theme breeze /2 of 2/
Updating theme breeze-dark /2 of 2/
Installing for user root
vtpoet
Post by vtpoet »
Yup. Softmaker is dead as a doornail on Tumbleweed.
payamf
Post by payamf »
I have contacted Softmaker support to at least get access to a previous version of the rpm (1064 I believe).
It's not on their server and I have not heard back from them.
Anybody have and older rpm?
vtpoet
Post by vtpoet »
I have an older RPM but it also segfaults. As far as I can tell, as of now SO is pretty much dead in the water as regards Tumbleweed.
vtpoet
Post by vtpoet »
H̶e̶y̶.̶ ̶G̶o̶o̶d̶ ̶n̶e̶w̶s̶.̶ ̶I̶ ̶u̶n̶i̶n̶s̶t̶a̶l̶l̶e̶d̶ ̶S̶O̶ ̶v̶i̶a̶ ̶Y̶A̶S̶T̶,̶ ̶t̶h̶e̶n̶ ̶r̶e̶i̶n̶s̶t̶a̶l̶l̶e̶d̶.̶ ̶F̶o̶r̶c̶e̶s̶ ̶o̶n̶e̶ ̶t̶o̶ ̶r̶e̶-̶r̶e̶g̶i̶s̶t̶e̶r̶ ̶t̶h̶e̶ ̶p̶r̶o̶d̶u̶c̶t̶ ̶a̶n̶d̶ ̶o̶n̶e̶ ̶l̶o̶s̶e̶s̶ ̶a̶l̶l̶ ̶c̶u̶s̶t̶o̶m̶i̶z̶a̶t̶i̶o̶n̶s̶,̶ ̶b̶u̶t̶ ̶t̶h̶e̶ ̶w̶o̶r̶k̶a̶r̶o̶u̶n̶d̶ ̶g̶e̶t̶s̶ ̶y̶o̶u̶ ̶a̶ ̶f̶u̶n̶c̶t̶i̶o̶n̶i̶n̶g̶ ̶S̶O̶.̶
Oops. Never mind. I accidentally installed Freeoffice. Couldn't upgrade to Softmaker Office. Removed and am trying to install Softmaker Office. Looks like it's locking up again.
Thank you for reporting this problem. I have forwarded the details to our developer team.
bernado82
Post by bernado82 »
@vtpoet
Your Tumbleweed seems not really up to date, actual version looks like this:
Operating System: openSUSE Tumbleweed 20231117
KDE Plasma Version: 5.27.9 (I'm using KDE Plasma, not Gnome)
KDE Frameworks Version: 5.112.0
Qt Version: 5.15.11
Kernel Version: 6.6.1-1-default (64-bit)
Have you considered upgrading to SoftMaker Office 2024 or NX? It works on openSUSE Tumbleweed and Leap 15.5!
You can install trial versions of Office 2024 and NX alongside version 2021 (but perhaps the file's association will be assigned to the new one?).
@payamf
I'm seeing many older builds available for SoftMaker Office 2021 in YaST Software:
ChipTunes etc... is my public playlist for Spotify (a truncated version is on Deezer also) with nearly 2100 titles and over 125 hours of listening, go to: open.spotify.com/playlist/1juVxm3beomqM38isNZRIj
payamf
Post by payamf »
@bernado82
Thanks so much. I had not thought of installing an older version from the repository.
I was able to successfully install version 1064.
I also downloaded a copy to archive just in case. First command lists the available packages in the repository. The second one downloads the specific version, and the third and forth find and copy it from cache to my home directory
zypper pa -ir SoftMaker
sudo zypper -v install -f --download-only 'softmaker-office-2021=2021-1064'
find /var/cache/zypp/packages/ -name "softmaker-office*"
cp /var/cache/zypp/packages/SoftMaker/x86_64/RPMS/softmaker-office-2021-1064.x86_64.rpm ~/.
payamf
Post by payamf »
I find this weird.
After installing version 1064 through YAST, I decided to be adventurous. I retried installing 1068 using zypper. Same results as before (stalled install).
Killed zypper, rebooted, uninstalled leftover 1064 and 1068 using zypper. Tried installing 1064 (not 1068!) through zypper. It stalled just like version 1068.
Killed zypper, rebooted, uninstalled leftover 1064 using zypper. Successfully installed 1068 through YAST!
Summary:
Installing manually using zypper has stopped working, for any version, it seems.
Installing using YAST software management worked for both versions I tried (1064, 1068).
I now have the latest version installed and working.
Thanks everybody.
The developers have found a solution:
You should use sudo -E instead of just sudo
We will update the instructions on our website.
