text background attribute lost
towo
Post by towo »
If you set text format to coloured background, after Save/Reopen this attribute is forgotten.
This failed already in Presentations 2021.
Devonboy78
Re: text background attribute lost
Post by Devonboy78 »
Do you mean that you are setting a text frame background fill? Performing this function does not lose its attributes when saved and re-opened
If it is not text frame background fill, how are you setting text format to coloured background, please?
towo
Post by towo »
It's not paragraph frame if you mean this.
Format - Characters ... - Background color (bottom right) - choose a color - OK
background color is displayed in text on slide
Save slide set, exit Presentations
Reopen slide set - background color is gone
Thanks for your post, if you will save the file in native file format e.g. PRDX, the text background feature will work but because PowerPoint don't have this feature, it will not work in PPTX file format.
Return to “Presentations 2024 for Windows”
