Unprotected formula
Mimile
Unprotected formula
Post by Mimile »
Good morning,
I would like the cells in which there is an unprotected formula to be marked with a color mark, like in Excel. Is it possible ?
Thanks.
Re: Unprotected formula
You can do it with conditional formatting using the following formula:
=CELL("protect", INDIRECT(ADDRESS(ROW(),COLUMN())))=1
(replace "," with ";" if needed)
See the attached file where cell C4 is unprotected.
unprotected.xlsx
(9.21 KiB) Downloaded 1996 times
Mimile
Post by Mimile »
Hello Miguel,
It works very well !
Thank you so much,
Cordially.
