Expired certificate @ https://shop.softmaker.com/repo/apt
General questions and answers about FreeOffice 2021 for Linux. Don't post application-specific questions here, but in the appropriate subforum.
isaacschwarz
Post by isaacschwarz »
I was following the installation instruction for Ubuntu (https://www.freeoffice.com/en/service/t ... icks/linux)
When executing the
Code: Select all
apt update
step I got:
Code: Select all
Err:3 https://shop.softmaker.com/repo/apt stable InRelease
  Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate.  Could not handshake: Error in the certificate verification. [IP: 136.243.7.241 443]
If you navigate to https://shop.softmaker.com/repo/apt, you will also see there is a cert expiration error. (the rpm page is also expired: https://shop.softmaker.com/repo/rpm)
Re: Expired certificate @ https://shop.softmaker.com/repo/apt
Thank you for your report, there was a problem updating the certificate, but this is now solved.
Return to “FreeOffice 2021 for Linux (General)”
