lookup() function bug?
vito
Post by vito »
lookup returns wrong value instead of error, see screenshot attached
stascheit
Re: lookup() function bug?
Post by stascheit »
The behaviour is correct (and corresponds also to Excel).
See the description in the manual:
Note:
If LOOKUP does not find a value that exactly matches Crit, the next smaller value is automatically taken.
If no smaller value exists because Crit is smaller than the smallest value available, the function returns the #N/A error value.
An error value is returned, if you have an example like this (Crit is smaller than the smallest value available):
Devonboy78
Post by Devonboy78 »
Just a small point; If the command is typed in as shown in the example =LOOKUP(3;A1:A3;B1:B3) ,Planmaker will report an error in formula Invalid characters.
The formula should read =LOOKUP(3,A1;A3,B1:B3) in order to work (manual, page 682, Syntax LOOKUP(Crit, LookupVector, ResultVector)
stascheit
Post by stascheit »
Sorry, my mistake. I used the European locale for list separators and cell range and not the US/UK locale.
But also vito does...
Return to “BETA PlanMaker 2024 for Windows”
