Just a minor nuissance:
I have updated to Ubuntu 23.10 (Kubuntu, to be precise) by re-installing my system. But then the .deb install file 1107-01 refused to be installed by QArk due to unresolved dependencies.
Installation by dpkg -i went smoothly though. Discover also installs .deb file without any troubles.
I'm not sure if GDebi of main Ubuntu 23.10 is giving any problems.
Kubuntu 23.10 installation : just a bit of nuissance
raitis.veksejs
Re: Kubuntu 23.10 installation : just a bit of nuissance
Post by raitis.veksejs »
Did you follow the instructions for installation on Linux?
Download an installation file .deb
Open a shell or terminal window and enter these commands to install SoftMaker Office:
su -
apt update
apt install -f ./softmaker-office-nx_1107-01_amd64.deb
Note: If you have not downloaded the .deb file to the current folder, replace ./ with the path to the .deb file.
su -
apt update
- SoftMaker Office NX
- ↳ TextMaker NX for Windows
- ↳ PlanMaker NX for Windows
- ↳ BasicMaker NX for Windows
- ↳ TextMaker NX for Mac
- ↳ PlanMaker NX for Mac
- ↳ Presentations NX for Mac
- ↳ TextMaker NX for Linux
- ↳ PlanMaker NX for Linux
