When you format the Heading 1 style to have a page break before the heading (usual for many longer documents), the epub export puts a blank page before each heading (not just starting on a new page). See attached files.
Whoops. No, see attached file because you don't allow upload of epub files...
Epub export bug when heading set to page break before
- TestOnly.tmdx
- (12.6 KiB) Downloaded 2668 times
Re: Epub export bug when heading set to page break before
Thanks for sharing your problem with the sample file, but we are unable to reproduce this problem. Please zip your EPUB file and then upload so that we can check.
Okay... so the bug only appears when the option to Create Table of Contents is selected. See attached zip file with two epub documents created from the same file: one with TOC not selected; one with TOC selected.
- TestOnly.zip
- (6.26 KiB) Downloaded 2629 times
Thanks for sharing the files and further details. I have forwarded it to our developer team.
Our developer team have fixed this problem and the solution will be included in the next service pack.
Brilliant. Thanks to all. Great customer service. No wonder I love Softmaker...
