NO insert hyperlink option
A@softuser
Post by A@softuser »
Couldn't find insert hyperlnk option under the insert tab in the menu. Please, help asap. i'm a newcomer in this community.
Re: NO insert hyperlink option
Thanks for your post. You can find Link (Hyperlink) option under the menu command Format.
Below is the screenshot for your reference:
Hyperlink in Menu.png (11.67 KiB) Viewed 8483 times
SuperTech wrote: Wed Nov 02, 2022 5:41 pm Thanks for your post. You can find Link (Hyperlink) option under the menu command Format.
That's a rather strange place to put it. Not exactly "intuitive." It's in the "Insert" menu in both Word (pre-ribbon) and Libre Office Writer.
