File format is not supported
Arian15
Post by Arian15 »
Hi i've been working on a document for a while now, just tried to open it today after saving it a little while ago today and its not opening. I just worked on it also can you please help recover this file this isnt the first time its happened with me where I've essentially (I hope not) lost the file but this one I absolutely cannot lose how do I fix this? The tmdx file does not open neither does the bak file.
Re: File format is not supported
Thanks for posting your problem. Please let us know which version of SoftMaker Office you are using.
Please share your corrupted tmdx and bak files so that we can check. If your files are private, please send them to the forum[at]softmaker.com with the link of this post.
