Display differences between Windows and Linux "Presentations"
mokaz
Post by mokaz »
Hi all,
1st thanks for your Office Suite, a very happy customer here.
Just a quick thing I'm trying to narrow dow, on some of my presentations, which passes from Linux to Windows and vice versa, I'm seeing sometimes some objects/vectors that aren't displayed. This mainly on the Linux version. See the attached images:
I've tried to save the file in the native file format, .prdx from Windows and opened it within Linux although the same "glitch" applies.
The "funny" part is that if I'm saving the file from Linux (which doesn't display the objects) and open it on Windows again, the objects are there..
Let me know if there is anything I could do/troubleshoot about it =)
Thanks,
Kind regards,
m.
Re: Display differences between Windows and Linux "Presentations"
Unfortunately, we don't support EMF vector images in Linux yet.
You may convert the images to PNG in windows using Irfanview or any other program of your choice.
In Linux, you may use the procedure described here: https://forum.softmaker.com/viewtopic.php?t=20868
