Custom Dictionary file location?
qwertt
Post by qwertt »
Where is the custom dictionary file located in FreeOffice?
General task: to have an option to add the dictionary with all additions i made, in case i need to reinstall OS.
Re: Custom Dictionary file location?
Thanks for your post. You can find the custom dictionary file with name useng.udc (which is language selected with udc file extension) in the folder path /home/<Username>/SoftMaker/Settings.
