Saving text frame defaults
rbm11111
Post by rbm11111 »
There seems to be a bug in TextMaker Professional 2021 (rev S1050.0807) 64bit.
Although there is box in the bottom left corner of the Properties box when creating a text frame, it does not work.
After clicking, a pop-up appears that allows you to select what features to include, when a new text frame is created, it does not use the defaults.
text frame default button.jpg (22.02 KiB) Viewed 5940 times
Re: Saving text frame defaults
Thanks for your post. This feature will make the settings default for that specific document only.
If this is not working for the same document also, please share the document in which you are facing this problem.
You can send your private document to forum[at]softmaker.com with the link of this post.
