boolean
DE685394
boolean
Post by DE685394 »
I want to do an overscore as used in boolean notation is this possible with Textmaker?
Re: boolean
Yes, you can use our Equation editor feature which is under ribbon command Insert | group Objects.
Please check the below screenshot of Overscore in Equation editor for your reference.
