Feature Request: Search (& Replace)
ChalkyW64
Post by ChalkyW64 »
Currently TextMaker clears the "Search" results pane if the item searched for is then modified in the document text. This then requires a repeat of the search to refresh the results. It would be great if only the changed entry was removed (or - if that's not possible - the search repeated automatically) to eliminate the need for a manual repeat of the search.
TextMaker currently closes the dialog window after a "Replace All" operation. There are times when consecutive "Replace All" operations might be required, in which case the dialog has to be re-opened via CTRL-H each time. It would be great if the dialog remained open so that this was no longer required.
Re: Feature Request: Search (& Replace)
Thanks for your suggestions. I have forwarded both to our product management as feature requests.
Our developer team have successfully implemented this suggestion, which will be included in the next service pack of SoftMaker Office.
Thank you.
ChalkyW64
Post by ChalkyW64 »
Thank you :D
