how to add text glow and animations
patrols
Post by patrols »
i can not find a way to add glows or animations to text?... please help
Re: how to add text glow and animations
Thanks for posting your query. You can add animations by clicking on ribbon command Animation | Animation scheme | Animation scheme.
Please check the complete details on our Presentations user manual.
patrols
Post by patrols »
many thanks for your reply, i have tried what you said, but its not allowing me to add animation effects to text and still not letting me add glow effects to text either?... please help
many thanks
Glow effect is currently not available for normal text. But you can add it for TextArt object which is available in ribbon command Insert | Objects group | TextArt object. I have forwarded this as a feature request to our developer team.
Please let us know if you still have any problem in adding animations to slide or objects etc. Please also share your sample file for better understanding.
Return to “Presentations 2021 for Windows”
