Cannot save Plan maker file
Bobha
Post by Bobha »
I can open plan maker (new download) sheet in Google drive and edit it, but cannot save it. Google gives a message about accessing sensitive information. Works fine under Windows.
Re: Cannot save Plan maker file
Thanks for reporting this problem. I have forwarded the details to our developer team.
The latest revision 1037 of TextMaker, PlanMaker and Presentations for Android optionally lets you use Android's system file dialog instead of the internal file dialog. This should allow you to access all cloud storage providers, as long as the corresponding app from the respective cloud provider is installed.
You turn this feature on via the "Appearance" tab in the Options dialog, checkbox "Use system file dialog".
Since this feature is still experimental, we welcome your feedback.
Return to “PlanMaker 2021 for Android”
