"Not Enough Memory" from TextMaker 2021
I am using TextMaker 2021 free version on a 175 page document with graphics. The "Not Enough Memory" error appears, what is the solution?
Re: "Not Enough Memory" from TextMaker 2021
Please check your computer's total memory, other programs which are consuming the memory and if there is infection in your computer which consuming memory.
Task manager will be the best tool for you to start the system diagnosis.
- Contact:
Also, with a 175 page with many large graphics, you could run into the 2 GByte RAM border for 32 bit applications.
The commercial version, SoftMaker Office 2021, also includes a 64 bit version which can use all the RAM of your computer.
Martin, Thanks...
I'd like to buy the commercial version if it can produce a large document and convert it to PDF. I plan to replace MS Word if the commercial version works.
If so, how can I update?
Thanks for considering purchase of commercial version. You can visit our online shop and purchase/subscribe SoftMaker Office 2021.
