Direct Download of FreeOffice 2021 Portable Version
Leec2020
Post by Leec2020 »
Hi,
I would like to be able to use the Portable version of FreeOffice on my laptop;
Only problem is it is a Cloudbook, with only 2Gb Ram and a tiny 32Gb eMMC drive, which is almost full.
The trouble is I don't have room to install FreeOffice first, then create the Portable version.
Is it possible to download a Zip of the Portable version that can be extracted straight on to an SD card to be then plugged into the laptop and used?
Thanks,
Lee
Re: Direct Download of FreeOffice 2021 Portable Version
Which operating system you are using on your CloudBook?
