Problem Character Formatting Hyperlinked Text
RKanarek
Post by RKanarek »
Greetings,
I have discovered that TextMaker 2021, revision S1032.0508, has trouble changing the character formatting of characters that consist exclusively of hyperlinks. If, however, non-hyperlinked characters are included, TM changes the character formatting properly. The accompanying document demonstrates this issue.
Cordially,
Richard Kanarek
P.S. Even if you folks aren't entirely perfect, you're darn close!
Character Formatting Issue.zip
(87.3 KiB) Downloaded 137 times
Re: Problem Character Formatting Hyperlinked Text
Thanks for reporting this problem. I was able to reproduce it and forwarded the details to our developers team.
Meanwhile, you can use ribbon command Home | Character for some formatting options.
