option to edit TOC present?
freeofficer
Post by freeofficer »
is the option to customize TOC present? Like indents, font style, fields.
Also, are the TOC entries clickable to jump to the relevant content in the document?
I'm asking because last time I used 2018 version, it wasn't present, so this may be a feature request if still not present.
Re: option to edit TOC present?
TOC is clickable now and there is an option "Use hyperlinks instead of page numbers" also in ribbon command reference | Group Table of content | Generate.
To update font styles etc you can do it manually after finalizing TOC.
