Rejoining
pool7
Rejoining
Post by pool7 »
Probably kind of useless post.
I had an account in the forum before, and when I tried to use it today to join the new private beta for SO HD for Android, it wouldn't work.
Tried password reset, no email.
I can only guess it was purged due to inactivity (which I understand, though I would have prefered if it was just disabled instead of purged). So I tried creating a new account, same username, and here we are.
Hope my request to join the beta is accepted :) (no hurry)
Thanks for the excellent products you make, and keep it up!
Re: Rejoining
I tried to find the account but there is no older account with this username or email ID.
I can confirm that your request is already approved, and you can install SoftMaker Office 2021 Apps on your Android device for Beta testing. :thumbsup:
Return to “Water Cooler”
